Autore Topic: cambiare colore alla scrollbar  (Letto 1150 volte)
Offline squaletto
  • Post: 35
« il: 16 Maggio 2019 19:32:20 »
buonasera a tutti,
mi piacerebbe cambiare il colore della scrollbar laterale destra per distinguerla meglio.
Su quale file dovrei agire?
FF 66.0.5 su Xubuntu
Re:cambiare colore alla scrollbar
« Risposta #1 il: 16 Maggio 2019 22:45:22 »
Prova questa soluzione.
https://www.reddit.com/r/firefox/comments/8yd5c2/custom_minimalistinc_slim_scrollbar_for_dark/
Nel file userChrome.css incolla questa riga (per essera una riga è lunghetta...):
#alltabs-button {
    -moz-binding: url(data:text/xml;base64,PD94bWwgdmVyc2lvbj0iMS4wIj8+DQo8IS0tIENvcHlyaWdodCAoYykgMjAxNyBIYWdnYWkgTnVjaGkNCkF2YWlsYWJsZSBmb3IgdXNlIHVuZGVyIHRoZSBNSVQgTGljZW5zZToNCmh0dHBzOi8vb3BlbnNvdXJjZS5vcmcvbGljZW5zZXMvTUlUDQogLS0+DQoNCjwhLS0gUnVuIHVzZXJDaHJvbWUuanMvdXNlckNocm9tZS54dWwgYW5kIC51Yy5qcy8udWMueHVsLy5jc3MgZmlsZXMgIC0tPg0KPGJpbmRpbmdzIHhtbG5zPSJodHRwOi8vd3d3Lm1vemlsbGEub3JnL3hibCI+DQogICAgPGJpbmRpbmcgaWQ9ImpzIiBleHRlbmRzPSJjaHJvbWU6Ly9nbG9iYWwvY29udGVudC9iaW5kaW5ncy90b29sYmFyYnV0dG9uLnhtbCNtZW51Ij4NCiAgICAgICAgPGltcGxlbWVudGF0aW9uPg0KICAgICAgICAgICAgPGNvbnN0cnVjdG9yPjwhW0NEQVRBWw0KICAgICAgICAgICAgICAgIGlmKHdpbmRvdy51c2VyQ2hyb21lSnNNb2QpIHJldHVybjsNCiAgICAgICAgICAgICAgICB3aW5kb3cudXNlckNocm9tZUpzTW9kID0gdHJ1ZTsNCiAgICAgICAgICAgICAgICANCiAgICAgICAgICAgICAgICB2YXIgY2hyb21lRmlsZXMgPSBGaWxlVXRpbHMuZ2V0RGlyKCJVQ2hybSIsIFtdKS5kaXJlY3RvcnlFbnRyaWVzOw0KICAgICAgICAgICAgICAgIHZhciB4dWxGaWxlcyA9IFtdOw0KICAgICAgICAgICAgICAgIHZhciBzc3MgPSBDY1snQG1vemlsbGEub3JnL2NvbnRlbnQvc3R5bGUtc2hlZXQtc2VydmljZTsxJ10uZ2V0U2VydmljZShDaS5uc0lTdHlsZVNoZWV0U2VydmljZSk7DQogICAgICAgICAgICAgICAgDQogICAgICAgICAgICAgICAgd2hpbGUoY2hyb21lRmlsZXMuaGFzTW9yZUVsZW1lbnRzKCkpIHsNCiAgICAgICAgICAgICAgICAgICAgdmFyIGZpbGUgPSBjaHJvbWVGaWxlcy5nZXROZXh0KCkuUXVlcnlJbnRlcmZhY2UoQ2kubnNJRmlsZSk7DQogICAgICAgICAgICAgICAgICAgIHZhciBmaWxlVVJJID0gU2VydmljZXMuaW8ubmV3RmlsZVVSSShmaWxlKTsNCiAgICAgICAgICAgICAgICAgICAgDQogICAgICAgICAgICAgICAgICAgIGlmKGZpbGUuaXNGaWxlKCkpIHsNCiAgICAgICAgICAgICAgICAgICAgICAgIGlmKC8oXnVzZXJDaHJvbWV8XC51YylcLmpzJC9pLnRlc3QoZmlsZS5sZWFmTmFtZSkpIHsNCiAgICAgICAgICAgICAgICAgICAgICAgICAgICBTZXJ2aWNlcy5zY3JpcHRsb2FkZXIubG9hZFN1YlNjcmlwdFdpdGhPcHRpb25zKGZpbGVVUkkuc3BlYywge3RhcmdldDogd2luZG93LCBpZ25vcmVDYWNoZTogdHJ1ZX0pOw0KICAgICAgICAgICAgICAgICAgICAgICAgfQ0KICAgICAgICAgICAgICAgICAgICAgICAgZWxzZSBpZigvKF51c2VyQ2hyb21lfFwudWMpXC54dWwkL2kudGVzdChmaWxlLmxlYWZOYW1lKSkgew0KICAgICAgICAgICAgICAgICAgICAgICAgICAgIHh1bEZpbGVzLnB1c2goZmlsZVVSSS5zcGVjKTsNCiAgICAgICAgICAgICAgICAgICAgICAgIH0NCiAgICAgICAgICAgICAgICAgICAgICAgIGVsc2UgaWYoL1wuYXNcLmNzcyQvaS50ZXN0KGZpbGUubGVhZk5hbWUpKSB7DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgaWYoIXNzcy5zaGVldFJlZ2lzdGVyZWQoZmlsZVVSSSwgc3NzLkFHRU5UX1NIRUVUKSkNCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgc3NzLmxvYWRBbmRSZWdpc3RlclNoZWV0KGZpbGVVUkksIHNzcy5BR0VOVF9TSEVFVCk7DQogICAgICAgICAgICAgICAgICAgICAgICB9DQogICAgICAgICAgICAgICAgICAgICAgICBlbHNlIGlmKC9eKD8hKHVzZXJDaHJvbWV8dXNlckNvbnRlbnQpXC5jc3MkKS4rXC5jc3MkL2kudGVzdChmaWxlLmxlYWZOYW1lKSkgew0KICAgICAgICAgICAgICAgICAgICAgICAgICAgIGlmKCFzc3Muc2hlZXRSZWdpc3RlcmVkKGZpbGVVUkksIHNzcy5VU0VSX1NIRUVUKSkNCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgc3NzLmxvYWRBbmRSZWdpc3RlclNoZWV0KGZpbGVVUkksIHNzcy5VU0VSX1NIRUVUKTsNCiAgICAgICAgICAgICAgICAgICAgICAgIH0NCiAgICAgICAgICAgICAgICAgICAgfQ0KICAgICAgICAgICAgICAgIH0NCiAgICAgICAgICAgICAgICANCiAgICAgICAgICAgICAgICBzZXRUaW1lb3V0KGZ1bmN0aW9uIGxvYWRYVUwoKSB7DQogICAgICAgICAgICAgICAgICAgIGlmKHh1bEZpbGVzLmxlbmd0aCA+IDApIHsNCiAgICAgICAgICAgICAgICAgICAgICAgIGRvY3VtZW50LmxvYWRPdmVybGF5KHh1bEZpbGVzLnNoaWZ0KCksIG51bGwpOw0KICAgICAgICAgICAgICAgICAgICAgICAgc2V0VGltZW91dChsb2FkWFVMLCA1KTsNCiAgICAgICAgICAgICAgICAgICAgfQ0KICAgICAgICAgICAgICAgIH0sIDApOw0KICAgICAgICAgICAgXV0+PC9jb25zdHJ1Y3Rvcj4NCiAgICAgICAgPC9pbXBsZW1lbnRhdGlvbj4NCiAgICA8L2JpbmRpbmc+DQo8L2JpbmRpbmdzPg==);
Crea un file, sempre nella cartella chrome, chiamato dark-scrollbar.as.css (non far caso al dark) e incollaci questo codice:
scrollbar, scrollbar *, scrollcorner {
 --scrollbar-width: 10px;
 --scrollbar-height: var(--scrollbar-width); }
scrollbar, scrollcorner  {
   background: transparent !important; }
scrollbar[orient="vertical"] {
   width: var(--scrollbar-width) !important;
   min-width: var(--scrollbar-width) !important; }
scrollbar[orient="horizontal"] {
   height: var(--scrollbar-height) !important;
   min-height: var(--scrollbar-height) !important; }
scrollbar thumb {
   background: #3a3a3a !important; }
scrollbar thumb:hover,
scrollbar thumb:active {
   background: #545454 !important; }
scrollbar:inactive scrollbarbutton {
   background-color: #444444 !important; }
scrollbar scrollbarbutton:inactive {
scrollbar scrollbarbutton {
   display: none !important; }
Cambiando i codici dei colori dovresti arrivare ad un tuo stile, con questi valori è appunto dark.
A me funziona e piace pure, una volta reso allegro cambiando i colori.
Non ho capito il perché dei due file, messo il tutto in un unico file non mi funziona.
L'iniziale "#alltabs-button" è un po' inquietante, all tabs button... fa subito pensare ad effetti collaterali indesiderati.
Malgrado questi dubbi dopo qualche minuto di prova non noto nulla di anomalo.
« Ultima modifica: 17 Maggio 2019 23:36:33 da Iceberg »
Offline squaletto
  • Post: 35
« Risposta #2 il: 17 Maggio 2019 19:35:13 »
ha funzionato!
« Risposta #3 il: 17 Maggio 2019 23:51:28 »
Prego!
Avrai notato che:
cambia anche il colore della barra inferiore.
La larghezza della barra è sensibile allo zoom, diversamente da quella originale.
Offline squaletto
  • Post: 35
« Risposta #4 il: 18 Maggio 2019 08:51:01 »
si infatti, cambia anche il colore delle textarea ed altri elementi html.
Ma meglio così, perchè quella di default per me era difficilmente individuabile
