Autore Topic: [Linux] Plugin flash a 64bit di firefox si blocca su Fedora  (Letto 4415 volte)
Offline francofranco1984
  • Post: 65
Re: [Linux] Plugin flash a 64bit di firefox si blocca su Fedora
« Risposta #15 il: 08 Giugno 2012 19:21:09 »
niente di niente, provate le soluzioni ma niente.
Con google chrome funziona tutto.
« Risposta #16 il: 08 Giugno 2012 19:23:05 »
Hai provato ad aprire Firefox da terminale? Nessun errore riportato?
  • Post: 65
« Risposta #17 il: 17 Giugno 2012 16:20:23 »
Ciao, scusami ero stato in ferie!
Questo è ciò che vedo avviando con il pc a 32 bit...
[samuele@danysamu ~]$ firefox
Warning: unknown JFIF revision number 2.01
(npviewer.bin:5763): Gdk-ERROR **: The program 'npviewer.bin' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
  (Details: serial 474 error_code 8 request_code 62 minor_code 0)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
*** NSPlugin Wrapper *** ERROR: NPP_HandleEvent() wait for reply: Connection closed
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2655):invoke_NPP_WriteReady: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2705):invoke_NPP_Write: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2550):invoke_NPP_DestroyStream: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2434):invoke_NPP_URLNotify: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2848):invoke_NPP_HandleEvent: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** ERROR: NPObject proxy 0x9d754dc0 is no longer valid!
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2219):invoke_NPP_SetWindow: assertion failed: (rpc_method_invoke_possible(plugin->connection))
  • Post: 65
« Risposta #18 il: 17 Giugno 2012 16:21:01 »
  • Post: 65
« Risposta #19 il: 17 Giugno 2012 16:21:19 »
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2150):invoke_NPP_Destroy: assertion failed: (rpc_method_invoke_possible(plugin->connection))
Offline fabrixx
  • Post: 5931
« Risposta #20 il: 17 Giugno 2012 18:52:21 »
Se rimuovi nspluginwrapper ?
  • Post: 65
« Risposta #21 il: 17 Giugno 2012 20:21:27 »
provato a disabilitare, fatto anche partire in modalità provvisoria. Niente
Offline fabrixx
  • Post: 5931
« Risposta #22 il: 17 Giugno 2012 20:26:28 »
Continuo ad avere sospetti su quel plugin.
Non c'è anche un pacchetto per fedora nominato nspluginwrapper?
https://admin.fedoraproject.org/pkgdb/acls/name/nspluginwrapper
Lo hai installato?
Se lo rimuovi?
Se al limite vai nella cartella ../firefox/plugins e rimuovi del tutto il file del plugin (file npwrapper.so) ?
  • Post: 65
« Risposta #23 il: 17 Giugno 2012 20:35:05 »
no, non l'ho installato. Magari è un "refuso" della vecchia fedora 14 da cui parte il mio pc.
la cartella firefox/plugins non contiene nulla di quello che hai indicato.
Provo a cercarlo e rimuoverlo.
Da dentro firefox, oltre alla disattivazione, non c'è un modo per eliminarli?
  • Post: 65
« Risposta #24 il: 17 Giugno 2012 20:42:19 »
ecco!
sotto la directory
/usr/lib64/mozilla
c'era una cartella plugins-wrapped
Spostata sotto radice, per sicurezza, chiuso firefox e riaperto adesso funziona! :O
ma partendo senza componenti aggiuntivi, non dovrebbe escludere il caricamento di tutto?
« Ultima modifica: 17 Giugno 2012 20:52:05 da francofranco1984 »
Offline fabrixx
  • Post: 5931
« Risposta #25 il: 20 Giugno 2012 21:57:10 »
Quello è un plugin non un componente aggiuntivo, disattivarlo dal menu Strumenti>Plugins di Firefox in questo caso non funziona.
Personalmente non ho mai usato l'opzione disattiva per i plugins ma preferisco rimuovere o rinominare il singolo files che costituisce il plugin.
  • Post: 65
« Risposta #26 il: 20 Giugno 2012 22:23:01 »
comunque, per chi ha il problema, basta dare il comando da root
yum erase nspluginwrapper
senza bisogno di spostare directory ;)
